Finally got to my Ord springs to put in work
how much did the springs settle? You have 40's? Any rubbing? I have already trimmed quite a bit, but still have some rubbing
dude, that is perfect. I have 40's so that should work fine. I may not have trimmed quite a much as you on the front rear.
What are the specs on your lift? I have 6 inch shackle on the front and rear with a shackle flip. I also have DIY4X easy inches. the way your truck is sitting is perfect clearance wise. I may just order the same springs from ORD
