Finally took pics of my AutoMeter project...
I was looking at Greg's photos over on NCBD and it looks like the inside of the gauge cups were painted in some of the pics. Did you paint the inside of your gauge cups?? If so, how did you go about doing it??
Guage cups? i didn't paint anything..well I take that back. I did paint the drk olive green you see on the back of the whole cluster/housing...
In pic #35 in Greg's album the inside of the cup looks like it was painted. It might just be an optical dillusion though.
Pic #35
Ok, this should be the last one. How did you remove the gauge markings on the o.e. clear plastic lens??
hahahaha The first time or the second...
Well Greg somehow managed to 'buff' his off with a dremal. When I tried that I burned streakes into the plastic and runied it all to gether /forums/images/graemlins/doah.gif
Second try i used my poket knife /forums/images/graemlins/yikes.gif with very light pressure you can 'flake' off the lettering and lines. Then I used McGuires(sp?) plastic polish for soft top windows and plastic in general. I bought it at AutoZone. It is a cream like rubbing compound. Worked well in removing the goast image of the stuff I scraped off /forums/images/graemlins/waytogo.gif
Just take your time and it will work out /forums/images/graemlins/woot.gif /forums/images/graemlins/grind.gif /forums/images/graemlins/weld.gif
hmmmmm, I'm digging that 10 pin connector... Wonder what it's from...
Here is mine, its not 3 years old sorry.
hahahah COOL! Thanks YJ!
I bought that pin connector kit but I cannot remember who makes it? Just a basic 15pin connector...
My fuel gauge crapped out so I have to troubleshoot that ..other than that the guges work great.
Nice Job YJ. I promptly saved these to my hard drive as well.
I started my gauge project last weekend which I am following (copying) Greg72 and Burts. I did the mounting different as my gauges came with thick plastic mounting retainers. So I used the factory backing plates that screw to the back but cut holes in them. Not pretty but I think they will seal out duct better. Couple questions though:
1. The autometer twist-in lights are a little small for the other 8 factory lights. What did you do to keep them in there? Is there another size available or were you able to modify them.
2. The orange needles for the speedo and fuel mine are really faded. Can you buy replacements or are they easy to take off and paint them to match the autometers?
3. I thought I would reset the odometer since my motor, tranny, xcase are fresh. How do you reset it.
4. Where do you get the pin crimping tool at?
Hope this helps you....
I used the twist in Autometer lights(same ones in the Sport-Comp guages I used) and a dab of clear RTV to hold them in place.
I ended up getting new guages from ChevyDuty. Never thought of painting them??
I tried to reset mine and well...I broke it! so again New one from ChevyDuty came set to 0000000. I too had a new engine so...
I use to fix copy machines so I had a crimping tool already. But radio shack hasum or anyplace that sells the pin connecters should have the tool also.
