Finally wrote the UltraBell swap article...
Damn good article!!! It ought to be on the tech page of CK5 /forums/images/icons/cool.gif . How hard was it cutting and grinding the case?
Cutting the stock bell was a snap since it was so thin. It took all of 5 minutes. Grinding the edges down was easy too, but I was a bit paranoid of grinding too much so it went slow. The hardest part was pulling/installing the tranny/tcase, the rest was cake. Now that my trucks running so good, I can stop and take the time to go back and do write ups on everything and get a tech section built out. There's so much good info floating around but not much of it has been captured... so I'm capturing it as I can.
Right on, keep that trick stuff coming /forums/images/icons/wink.gif BTW, are you headin out to Truckhaven in Oct? I should be there, barring any major disaster in Moab this month.
