Look closelyHere’s a quick pic of the adapter and bolts for reference. Apparently a gasket is available for between the adapter and block but no one ever uses them. I wonder if someone stacked a gasket or two in there. That would cause the filter to bottom out on the adapter before the sealing rubber hits the block.
Pull any washers below those bolts and those themIll pull the adapter and look
