77k5blz
That's not carmine red by chance is it?
No its a custom mix the grey is a ford color called dark shadow.
That is a nice paint job. My K5 will need a paint job in the next few years. The pearl white base/clear over red paint that the PO's friend did is now starting to peel. It showed off just a hint of red when the light hit the white paint.
I am in the middle of spraying primer on my engine bay and various engine parts, for my 79 C20. I am hitting the bare metal with etch, then everything with fill primer and black base and satin clear. It is a lot of work, but I think it will look very nice. I have only done small auto paint projects, never more than a hood or interior of a truck. That is pretty cool that you were able to do that in your garage. I couldn't fit my trucks in my garage, even if I took all the tools out of it.
Thanks alot i appreciate it it took forever if i can give any advice( i learned this the hard way) if your gonns use a two part urethane base clear stay away from rattle cans for primer most are enamel and it will peel when u put paint on thankfully i learned this before paint went on but i had to sand it all off nd reseal and prime. Use a 2k primer you mix with hardener youll be much happier with the results. Are u gonna post a thread of your build?
