finished welding gears (pics)
73redblaze
Aptos ca
finished up today, thanks for all the help guys, hope i did it right. also got the 64's installed today.
Not sure what you mean by correct position. Will the side gear sit down into the teeth properly? As far as I know it is not indexed to any particular position just so long as it sits in the spider teeth properly. I would think if the bottom one is correct the top should drop in :dunno:
drop in a crap load of steel chunks, bolts as you go.. saves on the wire:D
haha im going to. no my question is does the gear that sits on top (red arrow) have to be in a exact tooth or as long as she fits together it will be fine?
As long as it sits together it will be fine. :wink1:
ok SWEET im golden!!! i will be done soon and i will post some pics once i get her goin
