Resurrection_Joe
1 ton status
Ok, I just shaved and threw the 14BFF in yesterday and today along with new rear springs, so I have very minor things left to do on the truck. I know most of them, because they are individual projects, but there has to be a lot of generally universal things I am forgetting.
Ok here's the few projects I need to get done (not coutning major fab work)
Rear U Joint
Front Shocks
Tourque Everything Down
Wire In Winch
Fill All Fluids
Bleed Brakes
Bolt Up Front Shaft
Wire In Fuel Gauge
Front Hub Install
The Fluids I Can Think Of Are
Power Steering
Transmission
Differential
Brake Fluid
Motor Oil
So overall I've swapped in new steering, suspension, and axles
Is there anything you can think of that I am missing?
(Besides Shoving Golf Balls In The Tires....)
Oh yeah, what is the proper tightness for crown nuts on steering link ends? Mine are pretty damn tight.....
Anyway, have some pictures
Rear U Joint
Front Shocks
Wire In Winch
Fill All Fluids
Bleed Brakes
Bolt Up Front Shaft
Wire In Fuel Gauge
Front Hub Install
Power Steering
Transmission
Differential
Brake Fluid
Motor Oil
