Depends if you put the fire out. I have a 10lb on the back of my tool box and a 1 or 2 in the cab. I seriously want the suppression system.What's the minimum/overkill ratio to have on a rig?
True, I’m scared of a fire so I don’t think you could go overkill.@Babaganoosh "Depends if you put the fire out. I have a 10lb on the back of my tool box and a 1 or 2 in the cab. I seriously want the suppression system."
i understand that but at the same time I doubt anyone is going to have 5-10 fire extinguishers on their rig. Maybe they would but I think that falls into overkill. Especially in regards to the space for them
Mine is right in front of the driver seat on the floor. Exiting the vehicle is number one priority, grabbing the release handle and extinguisher is pretty easy when its right there.I mounted might at the bottom of the seat next to the doors on both sides. I figure if there's a fire in the cab you'd be jumping out so you could still grab them there and be out of the truck. Also quick to grab if you're already outside the truck.
Do you have dry chemical or Halon? Dry chemicals can ruin an engine.
I think Halon is being phased out. Just like r124 freon.I was in the process of writing "Halguard is so cheap why wouldn't you have one", when it dawned on me I should see what they cost nowadays. I have a 2.5lber, and holy crap at what they cost. I think this one was changed out 2 years ago. I'm pretty certain its now like 120% price increase.
Lol. Going to be way easier to smuggle fire extinguishers across the border than it was the big R12 tanks, could only fit one tank in place of the propane tank on pop-up campers. Fire extinguishers sir? Yes I have 24 in my camper... I'm scared of fire.I think Halon is being phased out. Just like r124 freon.
