MaizeBlazer
Newbie
Hey folks, I'm new here, I did a lot of searching but couldn't find what I needed. I bought an 89 K5 with a 350 this winter, it's rusty and wore out so I decided to put a rebuilt engine in it over the winter. I'm an ok shade tree mechanic, grew up on a farm so I do ok but had never swapped an engine before. Anyway, got the engine all in, no real troubles and get it started this morning, sounds good adjust the timing all is well. I go to shut it off and it won't die, radio, etc goes off inside the cab but the engine stays running. Never came across this before, new one on me. So I thought maybe I had wired the starter wrong as there were no leads on the wires they were just wrapped around the bolts when I took the old engine out. So I swapped the two small wires on the solenoid, then it wouldn't even start, so obviously that's not right. Swapped them back and now it won't start at all either. Cranks ok, have power in the cab, power to the alternator, power to the block on the firewall but no start. I couldn't check for a spark as I was working on it alone. Anyone have a clue? Could I have fried the coil? I don't see any fuses on the wires from the solenoid up so don't think that's it either.
Oh and so hopefully I'll get the starting fixed, does anyone have any ideas as to why the key switch wouldn't turn the truck off? I'm sure I've got all the wires connected right, only one way to connect them basically. When i pulled the coil wire it would die but other than that nothing worked. I don't believe it's the key switch either worked fine before and didn't look broken when I took the column apart.
Sorry for the long post and I appreciate any help. It's been fun working on this truck I just really want to take it for a drive!!!
Tony
Tony
