fitech efi in November
The pump has a sock filter. Then run the 30 micron FiTech filter post pump somewhere.
Fittings
thank you!! that rocks, i just hope the fitech filter isnt on back order.
this is how i bypassed the rubber hose in the middle of the frame. i have to get a longer 1/4 line to do it for the return. thwe stock one has some damage to it and i want it changed. going to run that for a return.
just added up the fuel filter fittings and lines and the total is 270 bucks, using the hard lines to run fuel up to the motor and return lines to the tank.only need 2 10 foot sections of fuel line instead of 40 feet. if i ran braided
