That's the exhaust system in my shopI'm very curious how the fuel command center works off road.
Also what is the door looking panel in the middle of the FiTech stuff?
What do you mean by skunked?Have you done the fuel command center skunked?
I was asking @skunked if he had used the fcc. I know he's done a couple installs. Sorry about the confusion.
thinking of this on a 366 bbc truck I am working on for a friend.
would be a simple / great upgrade over carb if he needed more reliable for faster get going jobs.
if you have played with it a few times whats the real feedback ? worth the cash ?
The initial test drive went well. I'll put some miles on it and post an update. So far I'mHere's my weekend project.
Well after a couple of weeks in I'm pleased with the throttle body. Performance has improved. Unfortunately because of winter and warming it up before driving I can't really tell if the mileage has improved. I do wish FITech would have put out some kind of tuning guide but I'm figuring it out. Also I was told the laptop software isn't available for the 400hp version, I think it would make adjusting much easier than the hand held programmer.
Now for the fuel command center. Not real happy with this one. Twice in these 2 weeks the float for the low pressure side has stuck closed causing the engine to die. The first time tech support wanted to blame the vent and disregarded my sticking needle diag. I had checked the vent and it was clear. The second time I talked to someone different and he admitted they've had calls about sticking needles. Right now this is my daily driver, so it has to be reliable, so I'm thinking about changing over to the inline pump approach.
Overall I pleased with this conversion and would suggest it to anyone with a carb.
I saw a conversation on another forum about using an AC Delco fuel filter #GF822 so you won't have to run a return from the front. I think it's a good idea.
The forum or the filter?Link?
