FiTech upgrade
for reliability the setup I run and many others is the Blazer baffled tank & sending unit with the Delco EP381 pump. If you're running AN lines there are a couple fittings that adapt the metric sending unit to 6AN. I can dig up the part numbers if you need them.
Could you get those part numbers for me please?
