crashandburn
Earlier this year I dropped a 94 TBI 350 into my 91 SAS'd S10 Bazer. The tired old 4.3 just wasn't very happy about 40" Swampers. But I had a hell of a stumble off idle, so bad that I could stall the engine if I hit it right.
On a hunch, I suspected the EGR was the source of the problem, since I had ruled out the TPS previously. Today I hooked up a vacuum hand pump to a tee running to the EGR and to a vacuum gauge. It would not hold vacuum. Tried it while running and while shut off. So I'm thinking I'm on the right track now.
Just for S&G's I pulled the vacuum line and ran it directly into the EGR, bypassing the EGR control solenoid. Now the truck runs damn near perfect. The stumble off idle is almost completely gone, in fact it is so minor that I could even live with it if I had to.
So, the EGR tested bad, but bypassing its control solenoid took away the symptom. Which do I swap out? I think the solenoid came from the 4.3, since the 91 and 94 motors had some minor differences and some things had to be transferred over. I'm not totally sure on that. The 4.3 did not have a hesitation problem. It had about every other problem, but responded off idle fine.
Also the check engine light is on. My OBD1 port does not work. It won't communicate with a scan tool, and even jumping terminals with a paper clip does not work, any ideas?
