Flaring tool recommendations
Desert Rat
Fetch the comfy chair
Tri-Valley, NorCal
Going to pick up a flaring tool set to do brake lines. Anybody have any recommendations or are they all pretty much the same?
I got a cheap one from a parts store and it would only make junk flares after the 4th or 5th one. I've seen some nicer ones I think from Eastwood.
once you get the Mastercool, the first thought is... "I can't believe I d*cked around with POS ones all those years..."
been using one of mastercools for over 6-7 years now. :bow::bow::bow:
had to get snap-on to order it for me . had to get all the info for them and then thay ordered it. now thay sell them also. all this cause thay only sell whole sale not direct.
I won't use it that much, but I also don't want to have to keep cutting the ends off of tubing because it doesn't work. I will be swapping in an F350 M/C and booster into my new old F150 and I need to change the tubes to accommodate the M/C. So, I don't need a $300 or more one, but I also don't want to spend $20 and ruin my brake lines trying to get one right. Something decent quality probably over $50 but perhaps less than $120.
thing with otc tools is its all china now . :doah:
Name something that isn't made in China, Korea, Taiwan, Indonesia, Mexico, or any other country. :mad:
What ever happened to making things in the good Ole' US of A. :crazy:
it was farmed out to Mexico in 87 by a white collar desk jockey....
and if its actualy made in the usa its few and far between on good or bad. i actualy think its not as good anymore. hate to say this. :doah::eek1:
That OTC link is identical to the crappy one I had. It did work ok for the first few flares an then the clamp stopped gripping the tube tight enough to work properly.
The last set I bent up the tubes myself and brought the tubes and fittings to a brake shop that had the tools.
So, any flare tools that are similar in design and function as the el Cheapo's but made much better for a reasonable price then? I thought I saw a $50 Mastercool somewhere....
