Flat belly(clocked t-case) worth it?
steve_kibbe
Spartanburg, SC
The 700r4 in my K5 went out and I have a replacement to put in.
Currently it has a np208 in the stock postion.
When I swap out transmissions I am going to put in the rebuilt np241
I have and was planning on clocking it either up 1 or 2 "notches."
I have the np241 and the clocking ring waiting to be put in but...
Is it worth the extra effort/money to clock it up out of the way?
I'll have to get a new front driveshaft and make a new crossmember...
I say it is.
A 20" to 24" belly clearance seems to work well with break over etc. If you can clock the t case and get that clearance with less suspension lift then you have less weight up heigh to tip you over.
It is one of the ways to get a lower CG.
Its worth it. Have you thought about a SYE while the case is sitting there?
The front driveline is fun with a clocked flat 241.... You will need to cut a hole in the floor and re-mount the passenger seat. You will want to look at my driveline...
You will have to raise the drivetrain about 3 inches to be completely flat.
Do you have any pics of your set up? I am thinking about rotating mine up. I already have the SYE and can make a square tube front shaft but will the CV still work or will it bind? I am only running 3" front springs but considering doing a 52" front spring swap in the future.
Sorry about the thread hyjack.;)
The cv wont work. I have 4inch springs and this is what I had to do.
Do you have any more pics showing the front shaft set up better up toward the t case? Do you have more details on your set up? Thanks for the infor so far.
When you said you had to raise the drivetrain up 3", are you just talking about the tranny/t-case mount?
Yes, to clear the frame rails for a pan.
I will try to find the full size pics.
What details are you after?
Wheels/Tires: 37 inchMAXXIS Creepy crawlers Drivetrain/Suspension: 350tbi,700r4,clocked np241 with a SYE 1350 yoke's, 2 piece front drive shaft, skyjacker springs, ORD cross over steering,ORD frame brace's, PRP limiting straps, 60/14/Detroits, ruffstuff diff covers, ORD disc brakes
chaddy, for what reason did you add the pillow block? was it to only get over the transmission x-member?
Part numbers for what you used would help.
Chaddy what effect if any does this have on the motor mounts and fan/shroud relationship? I assume you raised it simply with the custom x-member.
I was able to get mine to work by using 2 Tom Woods Super Joints. I got rid of the cv in the front shaft and got one of these u-joints at each end.
However I did not go completely flat to the bottom of the frame rails, but 1.5" lower as that was the size of the square stock I used to make the x-members and skid plate.
Clocking allows a much better break over angle with out having to add extra lift. A huge skid plate solidly mounted is a great way to get more poor mans break over as well. Have not looked back from this mod, but there are several issues to consider.
