flat top knuckle repair
YELL78
Registered Member
ALBUQUERQUE
i have a set of flat tops for my d44 but the on the driver side where the tie rod attaches is all oblonged, i was going to use another drivers side knuckle off of a different axle but i just read that your not suposed to do that is this true or can i use the different one or is there a repair for the old one?
If you use the stock tie rod locations and look for another knuckle, make sure the taper is drilled the same direction as the current one you are using. I mix and match knuckles all the time w/o issues.
But I like pauly's opinion best :)
