I was hoping that you would see this because I just knew you had a good clear pic of that cover.
If we can confirm which part numbers work for his transmission I have 8 of them, some 700r4, some 4l60e some 4l80e.I was hoping that you would see this because I just knew you had a good clear pic of that cover.
How do I find out the part number?If we can confirm which part numbers work for his transmission I have 8 of them, some 700r4, some 4l60e some 4l80e.
Spacing changes between them
I never paid attention enough to the part numbers on these covers but some will fit others.If we can confirm which part numbers work for his transmission I have 8 of them, some 700r4, some 4l60e some 4l80e.
Those look like the correct one.. how can I confirm on my end?View attachment 522921
I have a few more in my garage
Yeah I have a few variations and now I know what this is for.If your engine has an OEM oil cooler the driver side bar will be bent different for clearance and that side trans cover mounting point will be casted a little lower in position so keep that in mind when getting a replacement cover.
These 6 different ones.Those look like the correct one.. how can I confirm on my end?
A little.
John may know what fits what because he has owned all versions and is very particular to this type of trivial information.
Ok.Thank you. The space between the trans holes are..
Bottom going up 1-2 (2.75 inches) hole 2-3 (3.5 inches) driver side.
Passenger side; hole 1-2 (3 inches) 2-3 (4 inches)
