flexplate question
lak2004
Durango, CO
I got a TBI 350 that was mated to a TH350 tranny, will the plexplate work with my 700r4? Thanks
You just need to make sure the bolt pattern for the convertor is the same as what is on your flexplate. Some flexplates have a dual pattern and it will work for sure.
oops probably should have done that before I put the new engine in :doah:
It did bolt up though if that means anything? I still have the inspection cover off so I can check too
Did the engine come from a truck or car? IIRC the cars used the small 153 tooth flexplate and they use a smaller bolt pattern for the convertor so it will not work. If the engine came from a truck then it should have the 168 tooth flexplate and should also have the larger bolt pattern for the convertor in which case it will work.
