Flexy Pics.....
Beast388
Clinton, IA USA
Well, the pics aren't flexy....and neither is my Burb! /forums/images/graemlins/histerical.gif
I stacked up a few hardcore stumps in my driveway to test the flex of my Burb. I already knew my front shock are too short and would limit my flex, but said why not. /forums/images/graemlins/doah.gif
As you can see, the pass. front shock is pulling that corner of the Burb down, causing the rear suspension to flex even more.
Once I get longer brake lines and longer shocks, I may need to trim a bit more off the fenders. /forums/images/graemlins/hack.gif /forums/images/graemlins/grind.gif
Rear
Time to get the longer lines and install the shocks, that should help the front flex alot. /forums/images/graemlins/doah.gif /forums/images/graemlins/peace.gif /forums/images/graemlins/thinking.gif
Wow you really are from the midwest, aren't you? /forums/images/graemlins/thumb.gif
Love your burb, btw!!
Looks like that rear fender doesn't need any trimming /forums/images/graemlins/dunno.gif /forums/images/graemlins/histerical.gif /forums/images/graemlins/whistling.gif /forums/images/graemlins/doah.gif
Bored today huh?
Always nice to see your 'Burb on here /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
BTW, nice to see you found a good use for that brake drum too /forums/images/graemlins/waytogo.gif /forums/images/graemlins/waytogo.gif
Keep it around, maybe I will run mine across it someday /forums/images/graemlins/thinking.gif
[ QUOTE ]
[/ QUOTE ]
Yea man.....those 13" drums make great wheel chocks too! /forums/images/graemlins/histerical.gif
Thanks everyone for the compliments. /forums/images/graemlins/waytogo.gif /forums/images/graemlins/woot.gif
[ QUOTE ]
[/ QUOTE ]
Yep, rust sucks. It is hard to believe that it was rust free up until 1987 when I moved from NV to IA. /forums/images/graemlins/doah.gif /forums/images/graemlins/1zhelp.gif /forums/images/graemlins/histerical.gif
[ QUOTE ]
[ QUOTE ]
[/ QUOTE ]
[/ QUOTE ]
If it wasn't a little rough you wouldn't want to beat it. Now quit yer whinin and come here some weekend and play in the mud. /forums/images/graemlins/thumb.gif
Is it just me, or is the hook on the passenger side ... umm, stretched out a bit much? /forums/images/graemlins/laugh.gif
-- A
[ QUOTE ]
-- A
[/ QUOTE ]
uh....yea.....it is "stretched" out a bit! /forums/images/graemlins/yikes.gif /forums/images/graemlins/histerical.gif
I did that trying to pull a pretty big lilac bush stump out of the ground. I had to turn the truck around and attach the chain to the hitch. /forums/images/graemlins/yikes.gif /forums/images/graemlins/histerical.gif
A couple of good jerks and it was out. /forums/images/graemlins/peace.gif
