Floppy tilt steering
Lewiston, Idaho
So, my steering wheel has gotten progressively sloppier, and now it's to the point that you can push up and down on the steering wheel, and I get like 3 inches of travel. I read in a 4 wheel drive magazine that on dodge trucks and suvs they had this same problem, and all you have to do to fix it is take it apart, and throw some lock tight on the bolts that hold it together and it's fixed. Is this true for my 88 suburban tilt steering wheel? Anybody else experienced this?
thanks
the common fix is to locktite only the 3 bolts you can get too. The fourth is virtually infreakinpossible to get too, PLUS, they are inverted torx heads so you'll have to buy some special tools, unless you happen to know ME really well. (well enough to "borrow" my NOT LOANED OUT TOOLS!) :D
I personally tighten all 4, not impossible to get to if you use a pivot pin puller to take the tilt head off, and a regular 6 point socket will work to tighten them if you don't have a inverted torx
