bigblaze76
Registered Member
I was going to use 75w-90 (synthetic) to fill my 14 bolt FF. it has a detriot locker and I was told this was the best fluid for my 14 bolt???
Is that correct??
Can I use that fluid in my transfer case it's a 205 behind a TH 350.
MY next question is from the B and M web site....it recommends using the trick shift fluid (of course) for a tranny that as a shift kit installed in it...and mine does but the next thing I read caught me off gaurd...It recommends if you are not going to use trick shift for your fluid they recommed using the ford f type over dexron??? (see below)
any thoughts
STEP 6
Is that correct??
any thoughts
STEP 6
. Lower vehicle but try to
keep rear wheels off the ground,
if possible. Add 6 quarts of B&M
Trick Shift ATF. While Trick Shift
is superior in heat capacity, lubrication
and friction material performance,
if Trick Shift is unavailable,
we recommend Ford Type
F fluid over Dexron or Type A.
