flywheel question?
gator1959
will a manual trans flywheel from a 250-6 banger bolt onto a 350,and if so does it need to be re-balanced? it is a '79 engine w/a m20 trans.
'79 K-5,D-44HD(8-bolt),14 bolt(FF),4.09 ratio,427 rat,auto,38" rubber,currently taking body off frame
You might call the dealership and have them cross the #'s to see if they are the same.
<font color=green> Too bad ignorance isn't painful </font color=green>
