for thoes that put a D60 up front
If you have a ten bolt noe it will bolt right in if you have a d44 you will need new break lines. other then that a front drive thaft.
huh thats only if he wants to replace all that.
If you're getting one from like boyce equipment or somthing all you'd need is to change the Ubolts. Driveshaft will stay the same and everyhting else, i believe. Its a good idea to go crossover because of the ease and price in a d60.
i had a d44 & mine bolted straight in, u will need the spring plates from the D60
