hidesertwheelin
what modifications did you you make? I'm currently running them on my burb and I'm meh about them. It's a 1/2 ton truck with stock master cylinder and a 14-bolt FF in the rear.
Makes sense, look like thinner rotors to me, and 5 lug.
Can't drill the 5 lug rotors for the 6 lug pattern though, right?
Camaro's also used rear disks, but different calipers (in the 80's anyway, the e-brakes on those seem to be easily broken) so the 5 lug rotors might be sourced from those.
I used the 89 chevy 4x4 front rotors, had to have the center machined to fit the 60 hub on the rear. this was the kit recommended by WarnNewer ones had thinner rotors/calipers. Normally why they aren't used. I vaguely recall that there were some 6 lug rotors off a toyota or something that might have been the right thickness and bolt pattern for the later Cadillac calipers, but not aware of any 8 lug pattern that would be the same way.
They might "work" better since they most likely have smaller pistons. May not stop as well, but also may not have as much bias problems as some people do with the earlier ones.
"Metric" normally refers to the A/G-bodies from 78-88 AFAIK, perhaps some include all the GM vehicles from that time frame in the same group. Dumb way to designate them, but I digress.
He has the later Cadillac calipers, I think he is saying that the *rotors* from the '89 (with a machined hub), are the right width for the later calipers.
DorianHe has the later Cadillac calipers, I think he is saying that the *rotors* from the '89 (with a machined hub), are the right width for the later calipers.
I don't believe they are really any different functionally than the older ones, just the size is different. Plus the later ones were used a lot longer, so should be far cheaper to acquire.
I had looked into this swap in the past, pretty sure I already have the calipers somewhere (yes I have piles of them) but could never find a "bolt on" rotor, which pretty much stopped my thinking on it. At this point, having a couple rotors machined to make this sort of swap happen isn't a big deal. An off the shelf solution would be nice, but if it takes a few more dollars to make it happen, so be it.
Prices at rockauto.com, without core. Used 1985, year span is 1979-1985 IIRC. I have no idea which ones are being used, but appear Seville and Eldorado used same pieces. These are the only Cadillac applications shown with rear disks:
Seville and Eldorado: ~$70/side.
Deville: ~$75/side
You said the early ones are/were over $200 side with no core, that sounds about right to me.
Dorian
You are correct on this. Bad job on my part. I have a Warn full float on my blazer. That is the reason for machine work, it uses a bolt on 60 spindle and hub with the 6 bolt pattern. When Warn designed this, they used the Caddy rear disks( with e brake) and the front rotor off 1989 4 wheel pickup.
