I'm back at it as I'm looking to put it to some actual work this summer. Over some slightly warmer days this winter I did get an inline coolant heater installed that I had laying around. It's not as good as the block heaters but it does work.
Next up was a new set of injectors:
The old set was very dirty and probably just slobbering the fuel out, which doesn't help with cold starts. But now with the new injectors it started with about 10-15 seconds of cranking on just 1 battery although it was about 65° out. However before would have required ether to get it to fire. I have no doubts that the engine is probably tired and it does have some blowby but it still works so I'm going to keep running it.
The weird thing is it still misfires above 1600rpm. Unfortunately I haven't been able to fully test it or even get it up to operating temp as I have several other repairs going on. It misfires and pops out of the exhaust so I checked the injection timing and confirmed it on spec at 19°. I just got a new valve cover gasket so next I'll pull the valve cover and set the valve lash. I figure an exhaust valve could be tight.
Next on the list was just topping up fluids. So I noticed the rear diff was low and it took about a gallon to fill it. Of course it was low because the right side brake actuator seal was torn and blown out and the gallon I just put in was pouring back out onto the ground. So I put a drain pan under it and ordered new seals for both sides. I installed the new one on the right side but I decided to leave the left side as it looked okay. However this opened up a can of worms in taking the brake linkage apart straightening everything and getting both sides into adjustment spec. It appears that they were out of wack and just about all the braking was done with the right side only. Now both sides are close to even and the pedals are no longer bottoming out. Unfortunately I haven't driven it yet to see it this makes any difference, but hopefully it actually stops now because it definitely was sketchy before.
Next problem I'm working on is the power steering pump.
It loses fluid rapidly with no outside leaks other than a slow leak from one of the steering cylinders which doesn't account for the amount of fluid it goes through. My belief was that the seal was blown out and it was leaking into the engine crank case. However getting it apart didn't reveal a smoking gun exactly and I come to find out that it has 2 seals stacked on top of each other, one to seal each side from each other. And of course all the casing orings are shot too. Time for yet another parts order since I only ordered 1 seal because that's all the parts breakdown shows.
I guess I'll rebuild the leaking steering ram too while this is all apart. Might as well...
Next up once I get the power steering back together is the sad state of the hydraulic fluid milkshake, terrible condition of the hoses, and the massive loader control valve leak. I have a pile of hoses to go on the front loader now, but the loader control valve seals aren't going to be very fun. Also changing that fluid is also going to be great with 40+ gallons on it. But hey free backhoe right?
