I've got a line on a Ford Dana 60 front axle, and I want to know what issues I might run into...
If I get it, it would get used for a SAS into my big-block gasser Burb (1994, 3/4-ton). The Burb already has 4.10 gears, and so does this axle. It's an open-knuckle kingpin axle with open gears.
From the BOM:
-Application: 1988.5-1991.5 F-350 Monobeam
-U-Joints: SPL55-4X
-35-spline inners, 30-spline outers
-8x6.5" bolt pattern
Questions:
1) Does this particular axle have any quirks/weaknesses that I should be aware of that would make it undesirable for my application?
2) Any issues with availability/price of replacement parts (brake parts, seals, etc.)?
3) It's from a dually - I should be able to run HMMWV wheels unmodified on it (just like a GM DRW front), correct?
4) I've already got an ORD crossover/histeer kit designed for a GM D60 sitting in my garage. Which parts from that kit will not be compatible with this axle?
5) How much of a PITA will the spring perch width be (they're wider than the '78-'79 Ford axles which bolt right in...)?
From the BOM:
-U-Joints: SPL55-4X
Questions:
