Question for people who know and have some experience with ford d60's...I have a 93 2500 Burban that I'm planning to eventually do a SAS on. There is a chance I have a line out on a 1989 Ford Dually front dana 60. These years are still the kingpin style, which is what I want to make steering easy, these have the wider spring perches but not a big deal on my build as I'm only gonna run a 35" tire or less on it, so not a big deal, but my real question comes in on the hubs. Obviously I would need to ditch the dually hubs and get SRW hubs on there. From quick searching, I have found that SRW hubs for the d60 are pretty freaking expensive...however I've heard/read that you can use Ford dana 50 hubs and they can swap on the axle just fine...anyone had any experience with this? Do you have to replace the spindle to the dana 50 spindle too, or is it literally just take off dually dana 60 hub and install dana 50 hub and your done?
I would like to figure this out before I pull the trigger on anything...and in all reality, just the hubs is the only issue I've found with going with this axle.
Thanks!
Thanks!
I do have some spare Chevy dually wheels laying around that would probably fit.
