Ford rims on Gm axles , reability?
CyberSniper said:
So... does this mean we should all scrap our aftermarket wheels? :screwy:
How many tall glasses of stupid have been consumed today?
If you actually look at most GM wheels...
You'll see that the lugnuts center the wheel. Some old junk uses lug bolts and some foreign stuff uses lug bolts... most of these are hub-centric.
A fine example is a STOCK GM IFS wheel, hub, and rotor. You'll notice that the stamped steel center uses a small lip on it. On the back of the wheel there is a small recess from the stamping (if steel) or casting (if aluminum). True hub-centric wheels won't have this.
True hub-centric wheels are nearly an interference fit. Most GM wheels will slide right on. The reason why the center hole is as small as it is is for ease of putting the wheels on the vehicle. Think about how hard it is to lift a tire and get the lugnuts on a semi-floater axle. Now imagine a 115lb woman doing ~58 cars/hour like that. Most stock GM wheels will set on the center hub and you can spin the lugnuts on easy due to the fact that there is enough backspacing in the wheel and it can rest on the hub.
If the hub were actually holding the weight of the vehicle there would be a nearly-interference fit like the Ford oddballs. And wheels would be really expensive. Like Ford 7-lug expensive.
According to you silly people that believe GM wheels are hub-centric and the weight is supported by the hub I should be able to run with my lugnuts loose on my factory rally wheels with grease between the wheel and the hub. This is simply not possible (without catastrophic failure). The load holding is done neither by the studs nor the hub. It's done in the friction between the wheel mating surface on the hub/rotor/drum and the wheel. When you run your lugnuts up to 80ftlbs you're really increasing the friction between the wheel and flange.
According to most of you hoodlums we should all be dead because we run aftermarket wheels. I should be super duper dead because I run mag-style (no cones) aluminum wheels that have a good 1/4" between the center hole in the wheel and the hub. Better call up all the wheel manufacturers with your "discovery" and tell them to fix it. :haha:
AMEN!! :laugh:
:haha:
:saweet: What he said. :D
