Fought the cone washers and won
tonkatruckon44s
La Porte, IN
I was swapping my 8 lug axles in my k5 this weekend and it was my first time removing a steering arm. I never knew how much of a pita it was. I used a ball pein hammer and lots of heat. What has everyone else used.
When I was helping my friend swap a steering arm we just took turns with a mini-sledge. One guy wailed until he was tired then we switched. Mixed in some air chiseling and it came off eventually. :D
soak it all in pb blaster for a day or so them weld the nuts to the studs and back the whole works out. need to replace the studs but I would do that anyway
The big 'secret' is to never hit upwards on the steering arm. Side to side, and downward. I've done a few, without heat of any sort and never spent more than 15 minutes to get the stupid thing off the knuckle. Once the cone washers pop up I use a big flat head screw driver and a smallish hammer and spin them out.
Well i got all my 3/4 ton axles in and my disc brakes are all done but my brakes are a little spongy still i think i need to bleed them more since i put 4 new calipers on it
When i did my 8-lug swap I used a mini sledge on mine. Ended up breaking the upper ball joint. Good thing it was on the old axle.
Same here. Ive never had to use heat or weld the nuts to the studs. I think people hit them upwards, and that just jams the conical washer more. I usually pound until one washer comes loose and grab it with channel locks, then keep hitting.
Make sure the rubber on the master cylinder is installed right and sealed against the master cylinder.
Make sure the rubber on the master cylinder is installed right and sealed against the master cylinder.[/quote]
Wouldn't hurt to go ahead and bleed the master as well.
