What numbers are you supposed to shoot for? This is what I have come up with so far.
Yes I am trying to lay it out. Do you need the roll steer to be negative if you are goin to run a sway bar? I can lower my top axel links and it will be + 2 or 3.
Four link rear three front. I think I will mount the sway bar in the rear. More room.
Ok so what are the parameters for all of the other numbers. Yes I might have to make compromises somewhere.![]()
You will DEFINITELY make compromises....
Every suspension design is a compromise, there is no way around it. Usually the limiting factor is where you can place the link mounts. They never seem to fit in the places you want them to for best overall performance.
Post up a screenshot of the calculator once you have numbers you like. That's usually how guys do it.... And it makes it easy for the rest of us to provide quick feedback.
No matter what, you will certainly end up with interferences you didn't expect once you build it and start cycling the suspension. I've spent more than 9 months messing around with the front 3-link on my truck until I finally got everything REALLY dialed-in with no interferences. It takes a LOT of time to get things right....
-G
OK.... someone fill me in on why all of these calculations have to be done over and over on 3 and 4 link setups ?
I mean with as many rigs have been linked on this forum,,, isn't there a good set of measurements that "work" for a K5 blazer / truck /suburban
I guess I'm missing something.....seems that with as many trucks that have been converted on CK5... someone would have a good set of numbers for various frame / axle combo's.....
carry on....![]()
carry on....![]()
For every well-designed suspension that I've seen, it seems like there are many more on the internetz with some sort of flawed configuration. Heck, I've even seen some a couple stories on CK5 recently of "pro-built" and high-dollar link setups that we're done poorly and needed to be scrapped and rebuilt.
Ultimately, it's a huge financial step to take.... If you don't study the basics of suspension design, you won't know how to make your compromises to fit your truck and personal preferences. Maybe you get lucky and end up with something good....but the odds are heavily against you. Even if you decide to farm-out the job it never hurts to be well educated, so that you can speak intelligently with the builder about the build and where he plans to make the compromises.
"Engi-nerds" like me like to know how things work in painful amounts of detail.... And that was the motivation to write the calculator in the first place. I can appreciate that some guys hate that crap and would rather just build, test, rebuild, test, rebuild, test, rebuild, test, etc until the design works properly.
-G
