Hey all, well I'm sure some of you remember my post when I started beefing up the frame by removing the rivets and replacing with Grade 8 bolts and stitch welding for added strength.
Now I've redesigned the engine crossmember to give added strength and to allow for the crossover steering conversion I'll be doing in the next few weekends. Also I've added the ORD weld in steering box kit and triangulating bracket. If you look close you'll see a BEEFY crossmember in front thats welded on the frame right above the leave spring eyes for even more stability and strength. Take a look and tell me what you guys think.....
http://www.pacificnet.net/~waxer/Engine_Crossmember/
