On my 1990 Silverado I came across a frame crack where the torsion bar crossmember is located. Would it be best for me cut out the damaged area and weld in a piece in place or would it be more appropriate to simply weld over the damage with a much larger piece that is welded to a meater section of the frame?
The images below show the damage and also a piece of steel plate in place. I can just weld this in place....or cut the frame and weld it in.
Thoughts??
Thoughts??
