y5mgisi
1 ton status
Nice work man! What color are you going with?
Another choice may be a SF 14 bolt. Large 33 spline shafts, 9.5" ring gear and I think 3.42's were available...plus it can be had in 6 lug. Weight is also less by about 100 lbs IIRC. The only downside is that it is a 'C' clip diff, but that isn't that big a deal. For the size tires you're planning on a SF 14 would about live forever under your truck.
White with black accents etc. The colour is Polar White and looks like thisWhat color are you going with?What color are you going with?
AussieK5 said:brand spanking full set of MT's (15 " 33's ) ....... Its 8 lug all the way.
I was pretty freaked out at first cause I started looking at the pics before I actually read anything and couldnt figure out what was messed up with your dash. then it jumped up and kicked me in the face that your from down under and everything is backwards from up here. that thing is gonna be purdy when its done. one question though, does the tranny have the shifting linkage on the right side too? its crazy seeing all the stuff on the opposite side from what Im used to.No its on the left, it runs under the tranny via cable. Most other 70's era trannies from GMH the Aussie GM arm (TH350/400/Trimatic Glide etc) run under the tranny via a rod lnkage arrangement.does the tranny have the shifting linkage on the right side too?
Are you still on vaation from work? Are you going to paint it yourself? What happened to the frame? haven't seen any pics of that.
. I'll make up a booth and spray it myself. The frame has'nt had much done as the cab and panels need to be painted so they are weatherproof as it has to leave garage for the chassis work to start in earnest.
