74huggerorange
Registered Member
What I am wanting to do is bolt an 84 1/2 ton 2wd pickup cab on a 74 1/2 ton 2wd frame...any problems with this? does it use the 70's mounts or 80's?
Thanks guys
Thanks guys
Yes, you are correct '81 up for the mounts. On the K5 I think the frame is different 77/78 somewhere based on the way the rear floor is made?
