- Joined
- Aug 12, 2017
- Posts
- 15
- Reaction score
- 3
Does anyone know what the differences between a 1/2 ton and a 3/4 ton square body frames would be?
Same year, long bed vs long bed they are basically the same. There is supposed to be a minute amount of thickness difference but I don't think it's worth arguing over.
You will see differences in the front frame horn shapes and body bushing styles based on year, up to '80 and '81 on. I also believe some 1/2 ton tons use short 52" rear springs whereas 3/4 tons will be 56".
some 1/2 tons had 56” I thought?
Yeah, I just meant that I don’t think they are all 56” (1/2 ton).
I've heard the K5s referred to as 1/4 ton trucks, is that from a lighter weight frame than a regular 1/2 ton?
Any suggestions on a reasonable tow capacity for an 84 bagged K5 with a built 6.0, 4L80, FF 14 bolt with disc brakes?
My friend pulled his 24' enclosed racecar trailer for years behind his 78 k5, stock everything.I pulled my 19' Bayliner for many years with no problems.
