Frame question.
Kevin Sartin
Does anyone know what the differences between a 1/2 ton and a 3/4 ton square body frames would be?
Same year, long bed vs long bed they are basically the same. There is supposed to be a minute amount of thickness difference but I don't think it's worth arguing over.
You will see differences in the front frame horn shapes and body bushing styles based on year, up to '80 and '81 on. I also believe some 1/2 ton tons use short 52" rear springs whereas 3/4 tons will be 56".
some 1/2 tons had 56” I thought?
Both frames are 6 inches, suspension is the difference but that goes on the frame.... k30 I think goes to 8 inches
Yep, I had a 1/2 ton long bed '82 with 52 inch rear springs. It was 8 lug swapped and lifted, had parts from a few different years. When I first got it I didn't know anything about trucks. I bought parts for a 3/4 ton 82 for years before I actually figured out that the truck started as a 1/2 ton (or at least the frame did).
I've heard the K5s referred to as 1/4 ton trucks, is that from a lighter weight frame than a regular 1/2 ton?
Theoretically that could be said that a K5 is a 1/4 ton as it has the capacity to carry 5 adults. That would limit its load capacity in the bed. They have basically the same suspension.
Any suggestions on a reasonable tow capacity for an 84 bagged K5 with a built 6.0, 4L80, FF 14 bolt with disc brakes?
probably whatever the hitch is rated for. The short wheelbase of a K5 is a less desirable platform for towing IMO.
I pulled my 19' Bayliner for many years with no problems.
My friend pulled his 24' enclosed racecar trailer for years behind his 78 k5, stock everything.
He eventually got a crewcab but it did fine otherwise.
It's mostly about hitch reciever, suspension and brakes on the trailer.
Seeing that the k5 is a short wheelbase it helps a lot to get the shortest hitch to get the leverage behind the axle to a minimum, or a weight distribution hitch even better
