Jason4x4
So, I was at Mtnman's property last weekend, and we started thinking about the thickness of frames, since he has a Chevy Grave Yard, we took some measurements.
All the measurements were taken on the right frame rail, in front of the front crossmember and behind the bumper.
There is some minor differences, I imagine it is the steel descrepencies.
1988 1/2 ton 2wd suburban -- .162
1981 4wd Blazer ------------- .164
1987 3/4 ton 4wd suburban --- .190
1988 3/4 ton 4wd suburban --- .203
1970's unknown longbed frame- .196
1977 2wd 3/4 ton suburban --- .208
1986 3/4 4wd DIESEL longbed- .231
1979 1 ton reg cab & chasis -- .236
1984 2wd 1ton crewcab dually- .224
1982 3/4 ton reg cab longbed-- .230
With the minor desrepencies, it appers that GM used at least 3 different thickness' of frame rails.
If you have anymore, post up...
, am I close
