K5dreamer
Background info, see thread - http://coloradok5.com/forums/showthread.php?t=259991&highlight=franken+axle
Ok boys and girls. Wrecking the truck and getting fired have put this project on serious back burner. I finally got around to it today. Made some progress but hit a major pair of roadblocks regarding my SRW hubs.
Test fitting the DRW hubs and my swap in rotors showed they fit perfectly. and would bolt together just fine. When i knocked the wheel studs out of the SRW hubs and tried to fit them.... no dice. the SRW hub inner half is tapered and gets wider the closer to the middle it gets. the tip will fit into the rotor, but then it gets wedged stuck, about 3/4 of an inch from a flush fit. Not a huge deal, i could have the hub machined to fit, but its kind of annoying.
The second major roadblock is that the SRW hubs do not fit on my D70HD axle ends. They slide on just fine, but after installing the lock nut, and tightening it until it bottomed out on the threads, the hub has 3/4 to 1 full inch of side to side travel. Im very confused.
Was there a change in design of SRW hubs at some point? my D70HD is from 1985, my SRW hubs are from 1998.
Last point, as mentioned, the DRW hubs fit the rotors the way i want them to. And i know they will fit correctly on the axle. The whole reason im trying to get the SRW hubs to fit is for the extra 2in of rear track width to match the DRW D60 front axle. Is that necessary? will it be the end of the world if i run the DRW width D70HD behind the DRW D60 front?
