Free 6.2/6.5L Gaskets
kennyw
@squarebody.chop.shop on IG
Stevens Pass Highway, WA
I have 2 partial timing cover gasket sets sitting on my shelf. I believe I originally used the water pump gaskets but the rest is still there. Fel-Pro TCS 45554 was the original kit, but all that is left is (1) oil seal, (1) oil pan segment, (2) IP gaskets, and (4) water cross over gaskets.
Free if you want to pay $5 for shipping in a flat rate envelope, otherwise I will toss it at the end of the week.
Are these the gaskets I will need when replacing my IP?
if so I will take them.
Let me know so I can Paypal you the $$
Some of them are. It is probably not every gasket you need though.
I reread, and it looks like you also have the pan gasket which I need too.
I will take them, if I am missing a gasket I can get it seprate.
I know I should have it somewhere but can you PM me your Paypal?
Gaskets needed for IP replacement are:
Intake set
Coolant crossover
IP (triangular, 3 bolt holes and one large center hole)
Valve cover gaskets aren't needed for the job, but what better time to freshen them up?
Rene
Intake set
Coolant crossover
Rene
Unless you need to pull the timing cover while you are in there. You can get away with carefully pulling the 3 bolts out of the oil fill tube hole, but drop one and the cover has to come off.
