Hi everyone... hate to ask what should be a simple question but I'm starting to feel like I'm out of options. I'm in the process of putting a Lockright in the front 10-bolt of my 1990 K5. I've removed the auto hub cover, the first snap ring, and the spring underneath. I'm a bit lost after this point. I see a clip with two tangs on it (180* apart from each other) that appears to hold in a collar, but even if I pry the tabs apart, I'm unable to pull it out of the hub. There also appears to be an external snap ring but I am unable to remove it as it is inside the outer hub (the part that the lug studs either stick through or what they are pressed into).
Here's a picture of where I'm at now. No matter how I move the collar around to either engage/disengage the hub, or pry the retaining clips apart, I can't seem to get any further.
Thanks in advance for any help, this shouldn't be stumping me as much as it is!
