I just recently purchased an 87 blazer with what i believe is a 6" lift and 36x12.5 superswampers. I drove the 200 miles home with no problems.
Drove it around for about a week and then all of the sudden I hear a grinding noise from what i believe is the drivers side front axle. It only happens on moderatly hard acceleration. Soft takeoffs does not produce this noise. As well it does not happen when the 4wd is engaged. I have a suspition it may be the factory locking hubs. Has anyone experienced this? If the hubs do need to be replaced, as from what I have read manual lockers are the way to go, is it a direct swap?
Go with Superwinch or MileMarkers.
Not to mention Warn is local to me..
