You have an awesome support group here. You're going to have to start somewhere.
I agree with the awesome support group on here. I was thinking to myself when I put the post up, after searching over 300 of the 1 thousand post on here and still could not find an answer, that I was ask my question and it would be days before I heard anything. WOW, I had a couple in less than 1/4 of a day and several thus far. THANK YOU ALL.
With both tires off the ground and secured on Jackstands and the hubs locked, with the transfer case in 2wd you should be able to spin one tire and the other should spin too.
Tried this, as I tried to explain horribly earlier and when I turn 1 tire it would not spin the other tire at all, but noticed that the "knuckle" (as incorrectly identified earlier) and should be called the half shaft, was turning on the drivers side of the vehicle...however when I went to the passenger side of the unit and turned its tire, the half shaft u-joint was not turning, but it did turn when I rotated the driveshaft??? Balding quickly (lol) here as I'm ripping my hair out
With an open differential the other tire would spin in the opposite direction, with a positive locking differential it would spin in the same direction.
Correct, that is the way I understood it. That is why I tried the whole off the ground thing and turn tire by hand....
If one tire spins and the other doesn't there is something in between that is broken.
I agree and understand that. ??? question... If tires are off the ground, hubs locked, and I turn a tire by hand the other (being this is a limited slip diff) the other tire "should" rotate but the opposite direction of the tire I'm turning?? Correct?? and if that is true and the principal that something is broken, if the passenger side or drivers side hubs and not in good working order and not allowing it the lock the hub in correctly, then the other tire would not rotate?? Would that less than a watt light bulb moment be correct? and or yes, the gears inside the housing or broken half shaft.
Like Deuling said you can take off the diff cover and check the spider gears. With the cover open you can see if everything is spinning properly.
I'm not sure if you changed the gear oil when you serviced it, if not you should because of the overhearing from the damage.
Will do this when there is no snow on the ground, so I don't freeze.
If everything looks ok there, you will need to check the shafts. The reason I thought it would be the outer on the driver side is. I thought you said you can spin the tires and you could see the axle shaft U joints moving but the tire was not.
You're going to need a few special tools to service the shaft. I assume you have them if you changed the spindle.
One you get the spindle off you can pull the shafts out and inspect them.
I hope this helps. I've been through this several times myself.
