Hey, your supposed to paint the sliders before the install.
BTW, the large flat washers and the bolt head should be installed on the body mount side. The lock washers and nuts should be on the slider mounting bracket side. That's how I've always installed them anyway...
I would have sent you the winch mount, but when I pulled it off, I found that it was tweaked a little, OK a lot. I used 1/2" plate with a bend at the lower portion for extra support.
How did it bend? I'll tell you.
I knew I shouldn't have done it, but my neighbor was needing some help removing a very large tree from his yard. So being the good neighbor I am, I said I would just yank it out with the K5. That was my first mistake.
I attached a strap about 10' off the ground to the tree. I then pulled the rope out of my Ramsey Patriot 12K winch and thought the amount of leverage that high in the tree, surely will pull it over. WRONG!!! I started the winch and began to pull the tree over. The tree started making some terrible noises but was coming over. Then it stop bending and the K5 started moving. My next thought was to dead head the K5. That means, using a strap on the rear bumper, tie it to a bigger tree. That was my next MISTAKE.
I started the winch up again, and the tree started coming over and out of the ground. Then I heard a chilling noise coming from the K5, but the winch never slowed. Then the tree, roots and all slowly ripped out of the ground.
Come to find out, after the removal of the bumper, the mount had a good bend in it. I never thought the formed 1/2" plate would ever bend, but I was wrong. I guarantee that Ramsey 12K pulled more in the range of 15-18K before the tree (that was about 18" in diameter) decided to give it up...
Luckily the bumper kept the frame from being ripped to shreds. And the bumper and my frame came out without a scratch.
