reddog64
So i'm putting a dana 60 in the front and of course, want it locked...
No here's my thoughts...
A detroit with install is about 700 bucks...
A Twin stick for the 205 is only 200 bucks...
If i weld the front up (make it a spool essentially) and run a twin stick to easily engage/disengage the front axle... will this work ok for trail use?
On road, the hubs would be un locked so on-road is not a problem...
But off road, trail use, will i notice a problem turning with it lincoln locked, even with the front disengaged if need be?
