I'm very late to the conversation. I ran lunchbox lockers front and rear on 33's in rocks for about 6 - 8 years. I did that at the beginning of wheeling with this truck. 10 bolt front / 12 bolt rear with Yukon shafts. Some will say I wasted my money and polished a turd with the Yukon shafts but I got them dirt cheap and it was peace of mind. Horsepower and weight will snap the weakest point. Finesse and throttle control goes a long way. I never had any breakage running an under powered 350 with a TBI conversion and saved money I didn't really have. I also had disc rear brakes on the 12 bolt that I picked up for dirt cheap too. I did this in case I broke an axle shaft or c-clip. The disc brakes would help keep the axle from leaving the chat.
I knew I was going to go to bigger tires and a better engine but the issue that forced my hand was driving on a sweeping curve on the freeway as I began to accelerate. The rear locker pushed me into the next lane and I about shat myself. It only happened once, but once was enough for me. I knew not to accelerate and do stuff like that, but I was tired after a long run had a mental slip. I knew the mannerisms of those lockers and I drove around them. Learn those mannerisms and you'll be fine with lunchbox lockers.
The lunchbox lockers are easy to install, have great operational benefits but when locked, like to go straight. I never had an issue on the trail or road with them, with that one exception, and they helped so much while 4-wheeling. I never had an issue where I couldn't turn or turning was ever an issue, unlike the true selectable lockers.
I eventually went to the D60/14bb with air lockers front and rear on 37's with an LS swap after the 350 decided to polish itself from the inside out. I sold each axle and some pretty good money back. I do have to unlock the front on some really tight turns. I normally keep the front open and the rear locked when wheeling. The K5 behaves pretty well when doing that.
These guys know what they are talking about and provided some great information.
