Front driveshaft play.
scottsdale86
San Bernardino ca
How much deflection should be in the front drive shaft when grabbed and pushed up and down? Like when you are laying under the vehicle and doing it? I am getting a odd noise in 4wd when going uphill and uneven terrain. But only when going up. Flat surfaces and down is no problem.
Check the trans & motor mounts, i had a scraping noise when going up hills once, turned out they were wore out & flattish, still holding, but flat, that flatness set the front driveshaft closer to the crossmember and when everything torqued & twisted the CV part would rub on the crossmember alittle.
Mine has a pretty decent amount of play, i can't drive it more than about 40mph before bad vibes set in,
I think that might be it. I have some fresh rub marks on the cv part where it contacted the crossmember. I guess it doesnt help that the PO tweaked the crossmember backward because he got it stuck on something.
Yes, that does it too, now that i remember this, i think that was another reason mine rubbed, i also bent mine back alittle, well, back, up, sideways, twisted, all of the above :tongue1:
Yeah mine is angled backward. Do you know if the crossmember from another year truck (mine is a K10) will fit. I hate the 86' crossmember it hangs way to low. Also how do you go about fixing the bent frame? I was thinking maybe a torch and sledge and then reinforcing it with 3/8 steel plate.
