Front driveshaft u-joint, internal snap rings or external??
85mudblazin
Austin,TX
I noticed my front driveshaft, front u-joint is a gonner and it doesnt look like there are external snap rings that attach it to the driveshaft, I am thinking they got busted out and that is why the u-joint is loose, the new u-joint came with the external snap rings so I think they are external unless I got the wrong one, can someone tell me if the snap rings go on the out side or inside?? BTW this is for a 85 with a np208.
Thanks
-Chris
yup, thanks I finally got the u-joint out of there, the last snap ring fits very tight to where the u-joint doesnt move as good as it would if it was loose, I think the yoke is bent a little, is it ok to run it like this??
