front hubs.
mmsprint7
Registered Member
carson city NV
Guys I am new to the site and looking for a front hub to replace the one that the outer race is loose. I converted my 70 blazer to disc in front about 15 years ago and I used all the parts off a 73. They bolted right on. any Help would be appreciated. The truck has been in my family since new, still has original paint on it.
Mark
Are you looking for the nut to tighten against the race?
Mark
I have hubs.
If you can confirm the size of the spindle at the inner bearing race I can get the right hub for you.
In my opinion the best current scenario is ton convert over to the later style large bearing spindles and wheel hubs. Somewhere around 77 to 91. Very common and reproduced parts nowadays. The only thing you would need are the spindles, bearing sets, and wheel hubs to change over.
I have considered that option but will try and fine a hub first, someone told me that the axels would need to be changed as well. not sure.
