Front lift Springs
K10 KRAWLER
Carstairs, Alberta, Canada
Hello, I had a question about some lift springs that I have. I bought a used set of 4'' lift springs and was curious if the 1 ton and 1/2 ton versions were the same. I dont know what they came out of but I would like to use them on my Crew cab Dually project. thanks in advance!
go for it, theyre the same. while theyre out, replace the center pins though. preventative maintenance.
Yep, it's easy to do. Also buy spares and throw them in the glove box.
I bought a used pair of lift springs covered in mud. After cleaning I noticed one pin was bent. My local spring shop charged me like $0.85 for each pin.
