Front links*LOTS of pics*
balterbuilt said:
are you using air shocks in the front? If so what kind. I was thinking about converting to air shocks in the rear. possibly the front too but not sure if i want to lose my stability.
Yep Im running Fox 2.5"x16" air shocks. We have put them on a few larger customer's rigs and they have worked GREAT!! IMHO the 2.0's are only good for sub 3000lb rigs. Onece you get heavier then that you have to add alot of pressure which makes them unload easy causing lots of body roll and poor hill climbing unless you have a front winch.
With the 2.5's you can run alot less pressure and have ALOT more dampening.
i drive my rig to the trails. i've never riddin in an air-shocked rig but it sounds like you have exp with them How do they do on the street?
85mudblazin said:
My ram is push pull:D
(Im running full hydro)
Gotcha!
Seemed odd that you'd miss that when everything else looked nicely done.
i'm ordering mine from the coolest dude ever, keith at xtreme crawlers. 2.5"x13" travel. The are being mounted on my lower links which is why i'm going with less travel. Love the rig bro, just needed to see an actual fullsize with nitro shocks before i ordered...haha!!!
